Stairs with landing that is not parallel
    I am trying to create a concrete stair with a landing that is out of square
    The stair is cast insitu and revit will not let me create it as a precast or cast insitu stair
    As an wooden or steel stair it seems to work ok
    Also, if I make the landing so that the lines are all square is works as a concrete stair
    Can anyone help?
    Try to convert to sketch while in edit /create stair mode.
