"Title on Sheet" parameter field" ?
    I was perusing a thread in the Revit Struc family forum where someone asked how to change a sheet description without renaming the sheet in the PB. He was told to use the Title on Sheet parameter. Is this an OOTB RST parameter? I see no such parameter associated with sheets in RAC.
    As far as I know that parameter only exists for views, ​not sheets...
      right you are, I misread the post in question. Learned something new today and can make use of that parameter. Thanks!
