i have problem when make new family that it load me to the library instead!!!
    Hi i just faced some problems before, so i unistalled revit architecture 2011 and the re-installed it again.
    the problem when i make new family it shows metric library instead of metric template.
    metric library supposed only for components
    metric template list like generic models,curtian wall panel based,.... supposed to be for new family
    so what shall i do to fix problem i am facing right now?
    Hi Ahmed,
    It seems to be taking you to exactly where you have nominated in the Option Panel in the 2nd image you attached.
    Redirect it to the template library should sort it out.
    Ian Kidston
    http://allextensions.com.au
      Thank you Ian, frankly i do not understand how to fix.
        Find the path to the template library and insert it into the default path in the options
        Ian Kidston
          Thanks Ian that is worked
