how i can get aligned fill hatch pattern in revit?
    Hi everyone, i wonder if i can make cross diagonal fill hatch pattern aligne in revit like the one on the image ??
    Draw two Ref Planes at the corner and then use the Align Tool to align pattern in both directions
    Mark Balsom
      Thanks mark for reply , the problem is how i can select specific lines or group of lines of the hatch pattern so i can align it with reference planes ?!
        Use the tab key
          when i am using tab key i have to choose either wall or floor, ok i selected floor to align it with refrence planes a planes,
          not lines of floor hatch pattern with refence and here is the problem.(because when you align the whole floor , the floor keep its internal setting and one of it is hatch pattern alignment).
          so with tab key i can not select the lines of hatch pattern , i am selecting the floor.
            Place your cursor on top of the line and then hit tab key. If it's not working, check that you applied a model pattern, not a draft pattern. Draft patterns won't align since they are scale specific.
              actually i've had this problem trying to align a wall material pattern, i can't select the individual material pettern lines...the project was a 2011>2012 upgrade although i can't see how this might affect it....
                and once again you have held a mirror to my ignorance...thanks again Martijn, yet another rep for you!
                  Since I just ran into a similar issue - tabbing to the model pattern line will allow you rotate as well as align the pattern.
                  chad
                    Yep... But he had a Drafting Pattern.
