Scheduling Beam Z Justification
    Has any one found a way to get the Beam Z Justification (Top Bottom or center) to show up on a schedule? We have had to enter them manually in the past but I know there has to be a better way.
    Thanks for the help. :thumbsup:
    Wade
    You can obviously schedule the z-Direction Offset Value, but there is no access to the z-Direction Justification through the schedule
    Not sure if it is retreivable through the API either, but if it was you could possibly create a new parameter that is populated through an API App that reteives the value which would allow you to schedule the parameter value
    Revit BLOGGAGE
    http://www.revic.org.au
      Easiest way imho is to look at the way you're placing your beams. ALWAYS place them in a similar manner, (I use Top since that's where the load is) and then apply a (scheduable) offset.
        Ok at least I am not missing something.
        Note to Autodesk…… Please fix this.
        Thanks for the comments back!
