2012 Revit Tutorials
    Has anyone found Revit MEP 2012 Tutorials? Does Autodesk produce such things? Thanks.
    Haven't seen any, but I suspect that the only ones Autodesk have produced would be to demonstrate and new MEP features for 2012. If you haven't already done so, you could have a quick look at the Wiki site and or Autodesk's You Tube Channel. Try MEP 2012 - YouTube as a starting point
    Ian Kidston
    http://allextensions.com.au
