Hotfix – Apply material family parameters using the Paint tool
    Finally: Autodesk - Autodesk Revit Architecture Services & Support - Hotfix
    how does one install this Hotfix? The Readme is HTML gibberish
      Can't see the HTML file? Here's a copy paste:
      Installation Instructions
      NOTE: You must have administrative privileges on your Microsoft® Windows® operating system to complete the installation process.
      NOTE: You must have Autodesk Revit 2012 Update 2 installed on the system in order to apply this hotfix.
      This installation requires you to replace the following file:
      • RevitMFC.dll
      To Install the Hotfix on a 32-bit system
      1. Close all software applications.
      2. Make sure the Autodesk Revit 2012 Update 2 is installed on the system.
      3. Navigate to your product installation folder; for example C:\Program Files\Autodesk\Revit Architecture 2012\Program
      4. Rename the affected original file.
        • In the product installation Program folder, right-click the RevitMFC.dll file and rename it RevitMFC.bak.
      5. Extract the Revit_2012_Material_Hotfix.zip to a shared folder.
      6. Copy the RevitMFC.dll located in the x86 folder to C:\Program Files\Autodesk\Revit Architecture 2012\Program
      To Install the Hotfix on a 64-bit system
      6. Copy the RevitMFC.dll located in the x64 folder to C:\Program Files\Autodesk\Revit Architecture 2012\Program
        thanks Munk
