revit filter by phase and rooms
    I've got a project with 6 phases in 1 large manufacturing building, and of course due to the way the project is moving, phase 6 is happening before phase 5 and phases 3 and 4 are on hold indefinitely. The client is asking for a layout showing all the new work for phases 1, 2, and 6, but not 3, 4, or 5, and with the new filter by phase tools in 2022 I've actually got that part working pretty well. The issue is the rooms in the model are only going to show the snapshot in time for whatever phase I have the view set to. I'm planning to just stack some views on a sheet to get this to show correctly, but I was wondering if anyone has found a cleaner way to show room from multiple phases on the same plan.
    That's basically what I do to note room names in a demolition plan. Beyond that, generally, rooms that exist continuously through multiple phases will be copied to each phase so as to be "current", but I can understand why you might not do that in this case.
