Can Hatch Patterns be rotated in Revit 2012?
    OK in Autocad you can hatch and rotate the hatch pattern to whatever angle you desire. Can the same be done in revit 2012?
    If yes then how please?
    hover your mouse and [TAB] until you highlight one of the lines in your hatch, then click to select and use the rotate command. This also works for material surface patterns.
      Only works on model patterns though, not cut patterns
