Visibility of Schedules on Title Blocks
    Is there a way of giving a title block schedule a visibility parameter? I'm creating a 1 title block fits all as I'm currently submitting drawings simaultanteously to authorities and builders.
    Not really... The way I've worked around it, is by setting the schedule to no borders/lines (making it invisible, unless it contains data) and then manually adding the borders/lines as titleblock lines with a visibility parameter.
      ah k. thx.
        I think you can mask a schedule with opaque text(label) or a masking region. Either of these can have a vis parameter.
        Author of What Revit Wants
