Area Tags
    Area Tags
    This should be an easy one. I need my area tags to show to 3 decimal places but can only get to 2. I have changed project units in both the project file and the family file to 3 decimal places. My room tags are all showing 3 decimal palces but area tag not. What am I missing?
    In the family editor, select the label which show the area, and click Edit Label. Now select the Area parameter, and look in the bottom of the window for "#" This allows you to set the units af the tag, independently of what the project units are set to..
      Thank you so much.
