can not align post edge along baluster with wall edge correctly !!
    Hi, i am facing problem that when i make one single railing with baluster and post (the problem is that rail is taking path penetrate post).
    that is not here in my case , so i made two railing pieces but still face problem of can not align post edge with wall edge(if i tried the baluster take different offset and move from it place
    so what do you suggest to solve this problem?
    i attached image for further clarification of my problem
    If you want to do this, make a full 90 degrees turn.
      make rotation for the post or the whole railing ? because post will rotate railing simultaneously because railing host post .
        When you go into Edit Mode, you will see that your sketch line arc isn't a full 90 degrees. Revit will always place the balusters perpendicular to the sketch lines.
          i still can not solve the problem, i prefer that i am uploading the file for better diagnostic for railing in the first floor.
          also there is line of handril under post i need to hide those lines also.
          project residential first trying2.zip
