sweep do not work on creating shape i want !!
    Hi , i tried to make something that is going to be used a post corners on my railing, so here in Egypt this is the post shape that has something small crossing in one point (similar to pyramid) but i tried using sweep programme tell me can not sweep i make the sweep end less than half also with problems, what is the solution to make this shape ??
    Please no one tell me you can not (nothing is impossible)
    Right, nothing is impossible, the "impossible" just costs more, and takes a while longer...
    In this case though, it's not even close to being impossible - Just have a look here: How to Create a Pyramid with the Family Editor
      yes but this is non equal sides in rectangle so it will not be the same effect of pyramid or work as pyramid. i asked before this question but this does not work in this case because the explantion was in the link about the sweep method.
        It's hard (for me, anyway) to see exactly what is going on there. Can you post a better example?
        Dan
          Sorry, my bad - Missed the part of the pyramid being rectangular... Anyway, create a solid rectangular box, and "carve" it out by using two void extrusions... as in the attached.
          But like I said, nothing is impossible
            ooops this is not roof or floor this is the baluster post , can i make the roof on family editor of baluster post?!
              The above is a generic family, but the technique to create it, would be the same in any family category.
                Klaus Do you have version 2011 for the above? i do not own revit 2012.
                  I do, but it's to late in the evening to crank up obsolete software... Have a look at the image I provided - It's really very simple. One rectangular box, and two void extrusions (with different slopes) to cut the box from both left/right and front/back.
                  Speaking of late... What time is it in Egypt now? It´s like 0:40 here, and I'd figure that you are at least two hours ahead? Time to call it a day?
                    Nice idea i will try it in the morning , yeah now it is 0:52 am (but we still at the late evening)
