Does Revit 2012 offer a summary of the rendering job?
    I don't use Revit, but I'm building a system for a Revit user.
    My question is: After a rendering job is finished there there anything to show how long the rendering took? A log file maybe?
    I know there's the elapsed time during the render but I'm looking to find the total elapsed time if I'm not present as the job ends.
    Thanks
    When you start the rendering, you'll see a check box to close this dialog box when finished. If that is unchecked you will see how long it took when you come in in the morning.
      Brilliant! Thank you sir.
        That info is also stored in the journal files... You'd just have to search the journal files for the text in bold:
        'C 07-Oct-2011 22:44:37.024; 0:< Start Setup Render Framework
        'C 07-Oct-2011 22:46:44.800; 0:< Render Done
        And welcome to the Forum BTW :beer:
