Is this a known issue? When I embed a detail component into a profile, then use that in the project none of the fill patterns of the detail component show thru. Is there a fix for this?
Detail Components in Profiles Don't show Fill Pattern
Scott D. Brown, AIA | Senior Project Manager | Beck GroupTags: None
Hi, Scott. I made a test, using 2018.3.3. This works correctly in a wall sweep that is part of the properties of a wall, or in a wall sweep that is placed on a wall, or in fascias or gutters. It might work in other sweeps, too. It does not work the same for model in-place sweeps But you could edit the model in-place and add the detail item family at the same workplane of the profile of the sweep. Also, you could add a material to the model in-place sweep.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
Any ideas why a nested detail component in a family or a wall sweep profile would not show up in a section?
I modified a detail component...September 18, 2012, 06:02 PM -
Hey all,
I've added a wall sweep for my top plate, but want to know if there's a way to add the lumber "cut lines". Aside from creating...November 19, 2015, 04:38 PM -
This may be a ridiculously simple question.
I have previously not used wall sweeps on edited profiles.
The wall sweep only stays at the...April 1, 2013, 10:50 PM -
I am trying to create a wall sweep on an angled wall that I created by editing the wall profile. Parts of the wall are unaltered, so the wall sweep profile...June 5, 2018, 07:51 PM
Can i some how change the length of sweep path when i add it to the wall as a profile?
How can i make it? or... would you use another revit workflow...October 24, 2011, 09:32 PM
Monumetric Footer In-screen
