key schedules and parameters and WTF?
    Three parameters: Floor finish, base finish, wall finish.
    All three can be put into a key schedule. all three can be used in a tag.
    you cannot add shared parameters to a key schedule, you cannot use project parameters in tags.
    how do these three things defy what i understand to be the rules of revit. and if they are breaking them, how do i break them too.
    i would like to create a room tag that calls out the finish of an accent wall. I have one that does the floor, base, and walls, and the info comes from the key schedule. i tried making an SP but couldn't add it to the Room Style Key schedule, i tried to create a Parameter to add to the Key schedule but it only allows PPs. What am i doing wrong?
    Mechanical Design + BIM Management + Arch Viz
    Tampa General Hospital
    Sadly, you're doing nothing wrong.
    Even more sadly, Revit just doesn't do Shared Parameters in a Key Schedule
    I'd encourage you to go upvote this Revit Idea
    https://forums.autodesk.com/t5/revit.../idi-p/6254607
    but, triply sadly, the Idea has been "UNDER REVIEW" for 3 years now.
    Dave Plumb
    BWBR Architects; St Paul, MN
      So, any idea how i could go about accomplishing the task?
      I don't understand how these parameters can be used in both a key schedule and tags.
      There has to be a way to duplicate their abilities.
        You can use Dynamo to push the parameters around, but you need to run it to update.
        Julie Kidder
        Architect + BIM Director
