what is this distortion i see on the preview 3d?
    Hi everyone, when i make slabs on the outer edge of the wall ; i see its effect on the preview shaded with edge as in the image, is there is sysytem of priority like i want to show wall on 3d and in the 2d section i want to show the slab ??
    Looks like the wall and the floor is interfering... You should model it as you'd built it.
      Select the walls, click on Attach Top/Bottom, in the Option Bar set the option to "Bottom" and then select the floor. The walls are now linked to the floor and will dynamically update.
      Klaus is right though: the base constraints of your walls is set too low and is making the Walls and Floor overlap each other.
