How i can close this gap of stair to make it solid ?
    Hi everyone, just wondering how i can close the void of the stair in the image make it all concrete.
    Check the Monolithic check box in stair properties.
    If you want solid to the ground try a wall and edit profile.
    Mark Balsom
      i used two approach first, what you said ,second the model in place method the two have problem with me see the image please.
        Instead of two thin walls, create one thick one, where the wall thickness = width of the stair.
        Instead of a wall, you could also use a generic in-place family....
          well , i tried now approach of one thicker wall(basic wall generic). it is fine but the problem in render i have two separates(one Monolithic that its fill will be hatched for reinforced concrete, the thick generic wall will be concrete.
          In section now that is fine but the problem in render.
          the image attached maybe more clear for my question.
          ALSO, one more question why the last one is riser without tread or in other words i want to assign nose of stair to the last slab.
            Give the two concrete materials the same render appearance. And in the Stair Type settings, there´s a "End with Riser" check-box.
