Duplicating 3D Perspective view an an independent view
    I am trying to duplicate a 3D perspective view because I want to make a similar view with the same parameters in another area of the building. (I am trying to make a 3D floor plan).
    As normal protocol goes, I right click on the navigation wheel for this view and select "set current view as home" in order to lock the view in place.
    Since I want to make a similar, yet separate view with the same parameters, I right click and "duplicate view with detailing." I rename the duplicated view, and from there, I pan over to the desired area of the building for this duplicated view, and assuming it is an independent view, I adjust the camera. I then, right click on the navigation wheel for this duplicated view and select "set current view as home" in order to lock the view in place, as i did with the original view.
    For some reason I find, despite duplicating the view, both views have the same "home" orientation, but I want them to be separate. They are behaving as dependent views. How can I make these views independent of one another?
    [QUOTE=katewood1989;227080]As normal protocol goes, I right click on the navigation wheel for this view and select "set current view as home" in order to lock the view in place.[QUOTE]
    This is your mistake. Home is a single view orientation kind of like a default. Go to any 3D view, click home, and you will get the same resulting view.
    This is what you want to use for locking your view:
