Upgrade to 2012 Deletes Ceiling Type Mark Info?
    We just noticed in a project that we upgraded to Revit 2012, that we lost the info that had been entered into the Type Mark parameter for ceilings. I have a support request into Autodesk, but has anyone else experienced this? I even tested by starting a new project in 2011, upgrading to 2012, and had the same results.
    In case anyone else runs into this, here is Autodesk's reponse:
    I’ve reproduced the issue as you’ve described. I’ve documented and sent this case to our development team for further investigation. I’ll update you when I hear back from them after investigating the issue and confirming it.
      I had all the room tags disappear off one level...they were still there on the other three..
        I too had all the ceiling tags go blank for type mark.
