Show Hidden Hatch??
    Show Hidden Hatch??
    Hey Guys,
    I have a crazy question to ask of them gurus here...
    I have received a file from a relatively new revit user who has done some interesting thing with 'VG' and view templates....
    I have a very messy site plan where the roof was transparent, spot levels were accidentally placed on ceilings.... the list goes on.
    I turned the roof opaque and used the "show hidden lines" tool to bring the floor edge through and the plumbing fixtures. This is where the fun starts. The roof has a tile hatch. When the floor is shown through the roof, the floor blocks the roof hatch? Oh and it blocks the overridden plumbing fixtures too.... I have decided to use the linework tool as this need to be sorted asap. I have tried this with a new project, and the problem doesn't happen...
    Any Ideas?
    I used to be high on life, until I realised it was cut with Morons.
    Combating ignorance daily through learning.
    Was this from an architect? Could it be an RCP?
      ehhhmmm, you might want to post a part of the project for this one (or email if it's under NDA)
      First thing that comes to mind: are the views set to the correct Discipline?
        Okay,
        So it is getting weirder by the minute....
        Set to architectural, is floor plan.....
        I isolated the floor and roof to test, and it worked fine.... then I reset the view to find that the roof hatch disappeared?
        I isolated the problem to a filled region!!?!
        I have attached the file and think it may be a bug...
          Yep have seen that issue before. Defiantly a bug. It generally doesn't affect the print either, just the on-screen display
          Revit BLOGGAGE
          http://www.revic.org.au
            Excellent, then I will assume that it has been sent to adsk and work around it...
