Lost commands in Sheet View
    Hi again...not having a good day with Revit.
    Refer attached: I have lost the Crop functions etc in the bottom ribbon in Sheets....can't crop View Ports etc.
    Only tools available are 'Temp Hide' & Revel Hidden'
    Have looked under Manage etc & can't find how to reinstate the out of the box tools at the bottom ribbon.
    What have I done....& what is the fix?
    TIA...Steve
    Looks to me like you're in the Sheet, not in any particular Viewport.
    You have to have one specific Viewport open (double-click in it) to crop it.
    Dave Plumb
    BWBR Architects; St Paul, MN
      The crop region is not a function of the sheet but rather the view. Set-up your view the way you want to see it on the sheet.
        Thanx guys...I had already sorted out my senior moment....Steve
