how to create a stainless steel effect
    Dear Guys,
    i have a problem in creating a stainless steel material like the one shown in the pic? i tried to pick a few stainless steel material in the library but it turns out some parts are black. i put my rendered pic and could someone help me out with this problem.
    Thank you very much.
    It seems to me the black areas are actually the stainless material reflecting the shadows, and the stripes look to be the shadows from the awning above. Try turning the reflectivity way down in the material editor. I don't think it will look realistic, though. What you have looks correct to me.
    Dan
      I agree with Dan, experiment & turn down reflectivity. also, reflective materials will cause render times to sky-rocket.
        You might also want to look into Chrome materials. The sample you posted is probably chrome, not stainless steel.
          The reflective materails will cause some heartache with both the render times and getting it to "look" right. Try reducing the reflectance and see how that goes.
          Another thing to remember is that renders don't always need to use the correct materials to get the desired result. It is getting the brain to think it is seeing a certain material.
          Perhaps try using the paint materials with a gloss for example. or opaqe glass with a silver colour? Experimentation is the key.
          Best of luck.
          Andrew Harp
          BIM Manager GHD
          • Steel Materials
            I'm not big into rendering or materials but I would like to do some quick renderings. Does anyone know or can share the materials used to render the steel...
            February 20, 2013, 04:57 PM
          • Its all black
            Help.... I'm very new to this Revit lark & not up to speed with all the correct terminology so please bear with me & I'll describe it a s best...
            November 23, 2017, 11:26 AM
          • material specification
            i am from fastener manufacturing company,i got an inquiry of screws in specific material.
            as per drawing material is mentioned as ' St36-2 ' ...
            April 15, 2015, 05:29 AM
          • Materials libraries
            Hi there, I'm trying to render a family I currently have created. I am looking to use a chrome material for it but there is only one available chrome...
            September 16, 2016, 10:30 AM
          • Structural Steel Framing
            We are wanting to update our structural steel families to allow for a finish. In a perfect world, we could add a variable thickness layer to all of our...
            July 3, 2019, 02:53 PM
