How i can make like beam connected to wall and slab in section ?
    Hi everyone, when i take section it is nomal to show only slab and wall with detail ok, --but what if i have beam with reinforced concrete that connect between wall and slab i know how to do it in callout? but the problem how i can show all of this in section.
    Please help me in this.
    Thank you in advance.
    My best regards,
    I'm not quite understanding you. I want to tell you to just draw a section view through it. But, something tells me that's not what you are needing.
    If it is what you need, then just draw a section using the section tool. That should show the wall (assuming it's set to load bearing), the floor, and the beam. You will have to show the reinforcing steel with detail components.
    Dan
