What is best tools for creating fence wall with column supporting them ?
    Hi everyone, i wonder what is the best tools recommended or family template (if it is going to be done using family template).
    if there is hosted and nested to do this job correctly please let me know by steps.
    and thanks in advance for your help.
    My best regards
    Railing tool. All verticals are ballusters (one balluster for the posts, another for the spikes). All horizontals are rails by profile. Bottom is larger rectangular rail.
    Railings - WikiHelp
    Scott D Davis
    Sr. AEC Technical Specialist
    Autodesk, Inc.
    http://bit.ly/aboutsdd
      thanks a lot scott that is great :thumbsup:
        just small question, what about doors are we going to model it away of railing?( using wall and hosted door from my creation inside door family).
          Gates? I would model the gates using the generic model.rft or the site.rft. Just place them where you need them.
          Scott D Davis
          Autodesk, Inc.
            Since they're really a wall, I'd actualy model them as such, sketch the railings between each end post (which I might also be tempted to model as architectural columns) and host them to a level (offset from the wall's top face) so the railing's vertical bars (as balusters) don't need a fake hosting rail (or offset) to start them at.
            It's a shame you can't define rails that follow a change in direction in the vertical - then you could build the gates out a mirrored length of railing drawn to the length of the leaf. Then there was that natty beam-system trick for creating sketch-edited profiles using columns (as balusters) and beams (as rails) - but neither address the need for 2D symbols in plan - and would need management of regular instances with model groups acting as types. So probably a generic model would suffice, but you'd want to be sure to switch it to a door category before using it if you want to schedule it as a door. Albeit an external one. A gate at that. But we do. :thumbsup:
