Setting Preview
    Setting Preview
    Is there any way to set the Source View that is used for the Preview other than Options from SaveAs?
    Normally you go to Save As, then Options to set it.
    The problem is, I want to set it on a Worksetted project, and if I do a Save As, everyone will need to make a new Local.
    I can go in to Save As...Options and set it, but then if I Cancel, it canles the Preview, too.
    So I just want to set the Preview without Save As
    Munkholm
    Administrator
    Last edited by Munkholm; October 1, 2011, 12:46 AM. Reason: Fixed inline attachment
    Dave Plumb
    BWBR Architects; St Paul, MN
    Go to manage, starting view (2012).
    Edit: don't work for preview sorry.
    jbenoit44
    French Moderator
    Julien
    P. DAC
      I believe this will also set it: Manage > Manage Project tab > Starting View.
      Don't know if this gets pushed through the Central File though
        Thanks, guys, but Starting View is the View that displays when you Open a file
        The Preview is the one the shows in the thumbnail when you're Browsing from the Open dialog,
        and (I think) in the Recent Files screen, although I'm not 100% sure which View Recent Files uses.
        Dave Plumb
          right, sorry... Then no, there's no other way.
