How to enlarge a perspective view
    Working with the camera to get better 3D views- but can't seem to enlarge the Perspective view.
    Can anyone enlighten me?
    Thanks!
    Thanks!
    Have you tried the crop region resize tool?
    https://knowledge.autodesk.com/suppo...7336A-htm.html
    if the 3D view is on a sheet select the viewport ( don't activate it), using the resize tool will scale the view up or down.
      You can enlarge the actual view on sheet by selecting the crop region and then hitting the size crop button in the tool bar. Otherwise you just need to move the camera around to get closer to the target. If you use the look function in the steering wheel, you can walk around the with the arrow keys similar to enscape
