Door schedules: smart columns looking at details?
    Ok, so I was wondering if there's a way to make a smart schedule that sees details and would update if they change numbers or sheets. I imagine there is, so if someone can tell me what parameters/formulas to add to the schedule, that would be groovy :bb:
    Any thoughts?
    Thanks!
    John
    No, still a wish list item. Some folks use a Schedule Key that provides the list of details that can be referenced based on filling in the available detail references. This means that you can choose from a list of valid references, as long as you keep the Schedule Key and the actual details coordinated. It's a bit better than manually entering it for each one...slightly. Still have to manually choose a detail to reference, just not typing it as much. If you update a reference in the Schedule Key then any door that is referencing it will update automagically.
      Thanks Steve. I was afraid of that.
      Not really following you about the schedule key idea. Is this in the same door schedule or a separate schedule?
        attached a quick mockup example
