make custom opening for curtain wall ?
    Hi there, my question i want the opening to be custom organic shape on the tilted curtain wall.
    the problem also i feaced that there is no option in mass in place that i can change profile of curtain wall
    Hope you can help me
    Select the curtain wall, click Edit Profile and draw the opening you would want. Keep in mind though: it needs to be formed from Panels, which have limits in their freedom of form. If you want more, start experimenting with Panels by Pattern and Adaptive Components.
      i got the idea of panels by pattern, but the problem of the soid and void like on the image can not be done with me because the edit profile it is not active with with tilted curtain wall (done by model in place) only perpendicular curtain wall i can see the option of edit profile.
