Deleting Curtain walling / system panel
    We have a project within the office that was originally modelled with some curtain walling / system panels in. We are now being asked to remove these from the model and i cant find a way to do this. I can make them empty panels so they dont appear but we need to actually remove the panels completely so that they arent there at all. Is there a way of doing this please?
    You can delete the curtain wall.
    If there is a curtain wall, it consists of panels. You can choose if the panel contains something (a panel), or not (empty panel). You can also replace a panel with a standard wall type, in which case it appears as if there is no panel.
      Apols, the person had got the "select pinned elements" turned off in the model and therefore we couldnt select the grid to delete :banghead:
