Roof pitch/cut part of the roof
    Hi guys, I am having a problem with my roof, I am trying to render a view of my house and the problem is that the roof is inside my window, but if I try to cut ou the roof part,then the roof pitch is not center where I want it to be because the lining is not at the same distance at both end of the ''square''... So does anyone have a solution for this? thank you so much for you help!
    You can use the Dormer Opening Tool, Vertical Opening Tool, or modify the roof outline.
    Dormer Opening
    Vertical Opening
    chad
      Dormer Opening
      Vertical Opening
      You are AWESOME, Thank you so much my friend !
