Swept blend
    Swept blend
    Any way around this error?: "Unable to create form element: self-intersecting or singular geometry would result."
    Seems to work fine here. A reference spline with polygons at each end, then "create form".
      Profiles would need to be smaller or the path and curves bigger. I think it is giving the error because that bigger hexagon can't go around those curves without touching itself. The geometry of the sweep can't corss over itself or you get the self intersecting error.
      Jeff Hanson
      Sr. Subject Matter Expert
        That was it...profile size reduced and it then works - thanks
