Area Separation Lines Intersections
    Attached are some area sep lines, set up using the 'area rules'. So they automatically snap to the middle / outside of wall, which can be nice.
    But the corner intersections look awful, they either don't intersect, or they over-intersect. Is there any way to change that look?
    I too, wish they would clean up correctly. I just use the trim command to do it.
      I only ever have them switched on when setting up or modifying my areas. After that they get turned off in that view.
      Michael
      Canberra, Australia
        Me too, don't bother with the looks since it will never be plotted. I like the feature, since it comes with a pretty wide gap tolerance, which is a great time-saver imho...
