Custom Railing
This topic is closed.
    Custom Railing
    This will be my first attempt at custom railings...
    I want to build a custom railing for a balcony
    http://www.customrailing.com/
    like the one on the left minus the circles
    but i don't know where to begin..
    Thanks in advance
    JCM
    Spanish Moderator
    Juan Carlos Moreno
    Sisley Cosmetics
    Sorry, the link is not working for me.
      There is an extra http:// in the front of the link. Delete that and off you go.
      Gordon
      Pragmatic Praxis
        Start a new railing panel family, and create the pattern you want there (via extrusions, sweeps, etc.). Load that into the project where you need the railing, then create a new railing type with the horizontal rails set up as you need them and with the new panel you just made set as the baluster. You'll have to play around with the start/end/spacing/etc. to get everything the way you want, but it's definitely doable.
        Good luck.
        Arcturis
        BIM Manager
        Associate Architect
          Hi Juan,
          If you are on subscription, Phil Read presented a talk on this exact subject a year or two back. You will find it at http://au.autodesk.com/?nd=class&session_id=5380
          Cheers
          Ian Kidston
          http://allextensions.com.au
            Thanks Ian! I'll take a look at it tomorrow. I managed to get something done but it still needs some work I'll post some progress tomorrow
            Juan Carlos Moreno
            Sisley Cosmetics
