how to make like this shape ?
    Hi every one i want to make an object like this shape so what is the tools do you recommend that it will do the job and thanks
    How to Create a Pyramid with the Family Editor
      Need more info....what is this shape going to be? Looks to me like a curtain panel, and then i would use the curtain panel by pattern template.
      Scott D Davis
      Sr. AEC Technical Specialist
      Autodesk, Inc.
      http://bit.ly/aboutsdd
        ... or possibly an adaptive component.
          you could also use a floor or roof with split lines. If it was a floor or roof, that is.
          Dan
            it is not for roof it is intended to make it on small classic cloumns but here is useful link i found that was easy to apply How to Create a Pyramid in the Massing Environment
