Design Options + Materials
    Hi all,
    Can someone help me with using design options to show differing materials?
    I fully understand how the design options actually work, that's no issue. What I can't seem to get to work is the differing materials for each of the design options. ie
    Do 1=Brickwork
    DO 2=Render
    DO 3=Stone
    Andrew Harp
    BIM Manager GHD
    Are you sure?
    If you want to use Design Options with different materials you'll need to replace them per DO.
    For instance walls:
    Let's say your primary DO is brickwork.
    Create 2 extra DO's Render and Stone.
    Add the original wall with brickwork to the primary DO.
    Redraw the wall in the two other DO's but with matching types / materials applied.
    Done.
      Thanks Martijn,
      Yes, I am sure I understand the design option functionality, thank you
      Had a brain fade, for some reason I thought you could have one wall with 3 different finishes ie a finish defined by the design option, not the geometry.
      Not sure why it thought that though.
      Andrew Harp
      BIM Manager GHD
        Lol, no problem... Happens to all of us sometimes
          I wish this was the case.
          Author of What Revit Wants
            Would be nice to have the paint tool be aware of Design Options...
