Windows and Doors on walls question.
    I have a 2x6 wall with 4" stone.
    When I put a window or door on it, it goes flush with the stone.
    How do I make the windows and doors go on the 2x6 ?
    Easiest way is to create your own door that has a reference offset that the rest of the modeling is based off of... (instead of the wall centerline)
    I prefer to make this an instance parameter in case I use the same door or window type in a different wall type.
