create 3D views from walk-through keyframes
    i'm trying to create Navis walk-through using existing Revit walk-through, and creating separate 3D views from key-frames is what i thought the way out, if that is the case then how to "get" each 3D view from each key-frame in Revit? well, i don't want to duplicate walk-through view and edit it and next key-frame etc.
    i posted similar question @ https://www.revitforum.org/coordinat...k-through.html
