Text in Ribbon Disappears
    I have a reoccurring issue where all of the text in my ribbon will periodically disappear. The only way to solve it seems to be closing and re-opening Revit. If I receive an pop up from Revit, that will be blank as well. Is this a graphics card issue? Has anyone else seen it happen?
    Thanks,
    Sarah
    Sarah Foulkes
    Not a Revit Robot
    I'd guess so. Did you try the usual suspects (hardware accelleration, anti-aliasing, new video card drivers, and so on)?
      Thanks,
      Sarah
      I have seen this happen and it is typically graphics related. I have not yet tracked down if it is a certain driver/card that does it or if it is just Revit mucking stuff up. I've found that if you move the QAT below and then back above or vice-a-versa that it usually resolves the problem without restarting Revit.
