is there a way to insert a real live tile roof
    Hi everyone i was wondering if it is possible in revit to insert a real live tile roof just like on the image because when you make a section and rendering it will be 100 % realistic and aacceptable for rendering and documentation ??
    So are you trying to tell us the tiles on the ridges would be cut like that in the real world?! What world are you from?
      it is uncorrect i know that it was just made by tool that do not understand what is correct or not afteralll it is computer not human mind i know there should be ridge between the two intersection tiles but i just wondering if there is the same thing magic that can turn the roof into tiles about ridge in the middle between then somehow it is better to do ridge manually
        i think this is the worthy to looking into http://www.revitforum.org/showthread...le-for-Roofing
          or this one: http://www.revitforum.org/showthread...ll=1#post20255
          Julien
          P. DAC
            thanks jbenoit44 when i tried to download files in rvt on the useful link there, the page lead me to page not found i am not able to download those files that can guide me the tools that used to create it
              weird...I've just checked, it works for me.
              try here.
              Julien
              P. DAC
                thanks the link you just provided it is working but i have Revit architecture 2011 i do not have 2012 if it is possible to provide it with the version 2011 that will be great
                  So, on request, here is how this family works:
                  - generic model for a single tile
                  - nested into a generic model, line based
                  - nested into a framing template, twice, with the second one flipped / reference plane. constrain, parameters, etc...
                  - load into a project
                  - use beam system tool, choose this family a beam, then adjust the spacing
                  done
                  here is the "beam" family v2011.
                  enjoy.
                  PS: original line based model found here: RevitCity.com | Object | Spanish Tile Linear Family (you are aware now....)
                  PS2: the line based family is useful for corners and roof edges, my 2 cts....
                  Julien
                  P. DAC
                    Does anyone have a 3D example of where they did a roof like this? I can't figure out how to get the slopes on the beams. Any instructions would be greatly appreciated. I am talking about using the beam system.
                    Thanks
                    Max E Johnson
                    Civil Engineer
                    High Desert Homes
                    Las Cruces, NM
                    [email protected]
