Walls Below
    Walls Below
    What is the best and eaisist way of having walls that are below the roof to show hidden? Without filter orverides. I have people hounding me for a simple solution that I can apply in linked views. It cant be project/surface overides either.
    -Alex Cunningham
    Linework tool. Tab / pick lines to multi-select, then use linework too to make them dashed. The dashed lines will stay with the walls below if/when moved/edited.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      Thats a crazy idea. Building has hundreds of walls below the roof. Plus if new walls are drawn I would have to verify every single wall before printing. OMG
      -Alex Cunningham
        Well, your question specifically said "without Filters"--so...................
        Filters would be a more effective way. LOL
        Edit: my first reply should have included "use an underlay" and then Tab/ multi-pick lines, linework tool.
        cliff collins
        BIM there, done that
        Cliff B. Collins
          How could I filter walls that are associated 1 level below? I know I can filter by type... but I dont think I can filter by level association... right?
          -Alex Cunningham
            Make all walls bearing and set view to Structural discipline. New walls would have to be bearing as well. Not a good solution if you are using analytic and such though. People's definitions of best, easiest, simple vary greatly depending a bazillion factors at the time of the task. Why not view overrides anyway?
              I am Structural so I need to bearing walls to be bearing always. I am currently overiding by element the bearing walls below the roof on a instance basis. It just sucks to have to do this when Revit could very eaisly show things below or obstructed by other elements as hidden.. <angry face>
              -Alex Cunningham
                level below would be controlled with view depth... not?
                  Go to the floor plan that is below the roof. Select walls. In the instance properties, for "Comments" enter "hide". Then filter by Walls in which "Comments" is "hide". Then apply Fiter to roof view.
                    I think I'm missing something, but I would just do a view override and set roof category to transparent and wall projection lines to hidden.
