Changes to model during construction/sketches
    What's the best strategy for managing a Revit model during construction?
    For instance, there are little changes being made via SK's, yet I don't want their detail and elevation tags popping up all over my model.
    I'm thinking it might make sense to either create a new phase for them or create separate view names for SK views and filter them out. Any other suggestions?
    Use Filters. Set up a new Filter called Construction or CA, or SKs, etc. Then apply it to all the annotations and set up a visibility on/off for them.
    Create a View Template that controls the Filters and apply to all your views. Done.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      Cliff...I think I almost have my head around this...almost. Can you give a little more detail? Thanks.
        Sure.
        Check here:
        http://wikihelp.autodesk.com/Revit/e...4-Controll1534
        Cliff B. Collins
