revit 2017 Wrong acquired coordinates, not share same coordinate system
    I used the template , working with no problems on 2016
    Any ideas why this coordinates are not same? I tried to link it first with shared coordinates, but this message appeared:
    Differing Coordinate Systems '...files do not share the same coordinates, center-to-center positioning wil be used'
    So i linked again using Origin to Origin and acquired coordinates. And they came lightly wrong as on attached. I moved base point manually, but don't know if it's not going to create later issues.
    If you're dealing with Shared Coordinates, then it's the "Survey Point" you need to look at, & or you can do a "Specify Coordinates at Point".
    You may also needd to link in a trash file to wipe the current coordinates clean to retry the process of acquiring/publishing coordinates if you still running into issues.
