Exporting "Thin Lines" as Images or PDF's
    For example, if my view is set to "Thin Lines," my output is still thick lines. Doing a screengrab or printscreen isn't high enough res to do the job.
    I think the only option is to create a View Template where all categories and subcategories are set to line weight 1. Then you can apply and export, ideally with a dedicated Export view.
    A screen capture could work too, as long as you don't need a large image, nor anything to scale.
    Gordon
    Pragmatic Praxis
      Gordon's right. "Thin Lines" is simply a workflow override thing, it has nothing to do with the actual line weight in the model, and so has nothing to do with the line weights when exporting or printing.
        Yeah. I tried setting all lines to 1. It didn't affect to image export or the PDF printing.
          What exactly did you do? Printscreen?
