printing 3D views to PDF
    hi,
    I am trying to print one of 3d views to pdf for presentation reason.
    some how the print is comming out little pixelated and lines are too thick
    is there better ways to print to PDF
    Thanks
    Yes, it's called .dwf.
    But failing that, check your pdf printer settings :
    1. You may be emulating a regular paper printer you have.
    2. You may not have set your resolution high enough.
    3. You may have downsampling on.
    4. You may have many things going on that could be affecting the output
    If you're happy with what's on screen (with thin lines off) look to the printer first, not Revit.
    If none of that fixes it then come back and let us know how you've got on.
