Show level in 3D
    Show level in 3D
    Hi all,
    how can I view all element of a given level in 3D?
    Thanks
    Use a Section Box and adjust it to only include the elements on a certain Level. Then duplicate the view, adjust Section Box, and repeat as required.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      In addition, you could also use a multi-category filter set to elements hosted at (the desired) level(s).
        thank you both very much. Both solutions are great. I will look them up and try to learn them
          Orient to View!!!
          Open a 3D view>hit the little down arrow on the view cube>orient to view>Plans>(use desired plan)>adjust the view to appropriate angle(as it will appear in plan; though actually 3D and cut at the plan view's cut plane)>Save View as another name: rinse, repeat...
          -J
          http://about.me/JayZallan
          Tweet, Link or Blog me up!!!
            sounds great but you cannot "select" by filter, and you cannot turn off others, and you have to create each filter for each level, etc., hope i'm wrong.
            besides methods of orientation by view, combined w/ section box, you can also use multi-category schedule w/ level as the only field, select, show, close dialog, temporary isolate, etc.
              But you can duplicate a 3D view and set the filter.
                but you still cannot turn off others.
                for instance, (duplicate) 3D view has walls, columns, floors, roof, windows, doors, etc., and i created a filter only containing items i want to see say columns, you can use that filter to turn on/off columns, but you cannot turn off others like walls, floors, roof, windows, dooors, etc. by using that filter.
                you'll have to create another filter which will contain others, in this case walls, floors, roof, windows, doors, etc.
                  But you could also filter on everything that isn't a column (does not equal) and turn those off?
                  About the OP: you can do the same for all elements not on the desired level. Extra complication here is that not all elements can be filtered by level (for instance walls)
                    right, right, i missed that simple ..., typical over-thinking! thanks Martijin.
