the temp files
    the temp files
    hello
    I'm cleaning this morning turning the temp files (revittemp_ *) I still won 4 GB SD
    * I realize that there are also files named>> revitsavetemp a number
    question: can I delete them also ....? (If I win another 3 to 4 GB SD, it is always better than nothing
    thank you for the info
    http://archimages.blogspot.com/
    Yep, you can (as far as I know). These files were created after error shutdown and are redundant.
      Yes these can be, and even should be, deleted. I say they should be deleted because they have the potential to cause future Revit crashes if you leave them floating around in there. They have also been known to cause issues while saving if left around.
        thank you very much to both of you
