Joining a wall and a column messes up the composition of the wall
    So I placed a column inside one of my walls as such(picture 1).
    But when in join them, the thickness of the plaster and the brick layer gets disturbed for some reason(picture 2).
    This has never happened to me before and i'm frustrated because i can't close my civil drawings with these shenanigans revit is pulling at this hour.
    :banghead:
    Please help!
    Hi, Thats an Architectural column or an structural one?, and did you cut the wall with one of the cutting tools?
    E.A Poe
      1. I used a structural column.
      2. The only thing that I did between pictures 1 & 2 is that I joined the wall and column.
      Sent from my A0001 using Tapatalk
        ok I see, and did you check the priorities for the layers in the Object style Dialog box?
        E.A Poe
          Yes. It is an unusual problem. The properties of the wall stay the same but the layer thickness changes in the display.
            That is bizarre. What happens if you nudge the column across the other face of the brick/plaster wall?
              As soon as the columns breaks the surface on the other side, the layers become normal again (pic 3).
              I kept on nudging it further and this (pic 4) is what happened when the earlier surfaces aligned. It's the strangest thing!
