Wrapping of Compound Wall
    Hi all,
    I am facing some troubles in wrapping the compound walls.
    Firstly, here are the components of the compound wall:
    The Wrapping of this wall works OK when the walls' components are coming out from the same level:
    BUT, the Wrapping of this wall DOESN'T works OK when the walls' components are coming out from DIFFERENT levels:
    And I need to draw the compound wall coming out from different levels.
    HOW CAN I DO THAT?
    Help me, please.
    Have you tried using the 'Wall Join' tool to cycle through potential join combinations?
    I find Revit gest confused depending on the order that walls are created/joined. Try selecting the vertical wall (from the snap above), then click and hold the end handle of the wall. Upon release, the wall may miraculously clean up correctly.
    I used to be high on life, until I realised it was cut with Morons.
    Combating ignorance daily through learning.
      That is because the automated simplifications of Revit's wall-join behaviour can not, (and arguably should not be expected to) second-guess how you intend to handle such a junction in all dimensions - and why I, along with many others, have long abandoned using compound-layer walls.
