Colour of walls in plan view / 3D
    Hello,
    I want, in Plan view to see the concrete walls with blue colour, the isolation walls with green colour etc.
    And also I want in 3D to see the concrete walls with a grey colour and the isolation walls with a white colour.
    Could you please give me some guidelines?
    Thank you in advance!
    Originally posted by MARIA1993 View Post
    Hello,
    View filters!
    https://knowledge.autodesk.com/suppo...B7C46-htm.html
    after you have created your filters add them to your view templates for use in other views
      The answer is the same in the case that I want to control the thickness of the lines? For example the lines for concrete walls - 0.50 , the lines for isolation walls - 0.25 etc...?
        If you can isolate specific wall types through say, type comments, yes, you will be able to change cut/ projection line thicknesses. You have the same options with filters that you do with visibility graphics and object styles - ie. projection line, surface pattern, transparency (not in OS), cut patterns, cut lines.
        Element visibility is a controlled hierarchy. Object styles > project wide default. Visibility graphics > view default. View filters > specific elements per view.
          Thank you for your help. I follow this video https://www.youtube.com/watch?v=dqJBM0i9DBM , but when I apply in the V/G the filters, in the floor plan I see the colour that is assigned in the Graphics of the material.
          Any idea?
